Laminate In The Primary Entryway? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-23-2006, 06:28 AM   #1
Laminate in the Primary Entryway?
Is it a good Idea to put a laminate floor in the Primary entryway (where ti will get wet) If so what kind/ Brand??? Bamboo Maybe?
mdlbldrmatt135 is offline   Reply With Quote
Old 12-23-2006, 08:33 AM   #2
Darylh's Avatar
No not a good idea. Water will damage your floor and also any grit from shoes will scratch the finish. What about tile, I have it in my entry and oh what a pleasure.
Darylh is offline   Reply With Quote
Old 12-25-2006, 09:13 AM   #3
I keep trying to tell thet to my other half.... run tile along the wall ... and put laminate in the rest of it.............
Old 12-25-2006, 09:32 AM   #4
Darylh's Avatar
I was lucky there, my wife wanted it. If you can't win on this then I would concider 3/4" hardwood. Sand the surface to except some polyurethane and float a couple of coats to seal up the joints. I did this at my dads with prefinished hardwood years ago in there Dinning room which has a sliding door going outside and has held up real nice. Just a thought. Merry Christmas
Old 12-27-2006, 02:42 AM   #5
So far, so good
I installed laminate (Dupont) in the entryway. I ran a bead of silicone caulk/sealant between the door jam and floating planks. I also have a small area rug down to collect dirt, rain, etc. So far, so good. Does anyone have suggestions on how to close gap that's formed between planks on fully installed floor?? This is not near the front door, so it's not related to the entryway install. Thanks..
pickel011 is offline   Reply With Quote
Old 12-27-2006, 12:40 PM   #6
Floorwizard's Avatar
gaps are gaps.
close one up to start another.
I would be against lam in the entry, but then again, I live in Alaska.
Vinyl or tile for sure.
Floorwizard is offline   Reply With Quote
Old 12-27-2006, 09:11 PM   #7
I finally convinced her..... LOL Tile it will be,...... (Hopefully somethin' Stock...LOL
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 02:25 PM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 08:43 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
