-   -   Laminate in the Primary Entryway? (http://www.diychatroom.com/f5/laminate-primary-entryway-5533/)
mdlbldrmatt135 12-23-2006 07:28 AM
Is it a good Idea to put a laminate floor in the Primary entryway (where ti will get wet) If so what kind/ Brand??? Bamboo Maybe?
Darylh 12-23-2006 09:33 AM
No not a good idea. Water will damage your floor and also any grit from shoes will scratch the finish. What about tile, I have it in my entry and oh what a pleasure.
mdlbldrmatt135 12-25-2006 10:13 AM
I keep trying to tell thet to my other half.... run tile along the wall ... and put laminate in the rest of it.............
Darylh 12-25-2006 10:32 AM
I was lucky there, my wife wanted it. If you can't win on this then I would concider 3/4" hardwood. Sand the surface to except some polyurethane and float a couple of coats to seal up the joints. I did this at my dads with prefinished hardwood years ago in there Dinning room which has a sliding door going outside and has held up real nice. Just a thought. Merry Christmas
pickel011 12-27-2006 03:42 AM
So far, so good
I installed laminate (Dupont) in the entryway. I ran a bead of silicone caulk/sealant between the door jam and floating planks. I also have a small area rug down to collect dirt, rain, etc. So far, so good. Does anyone have suggestions on how to close gap that's formed between planks on fully installed floor?? This is not near the front door, so it's not related to the entryway install. Thanks..
Floorwizard 12-27-2006 01:40 PM
gaps are gaps.
close one up to start another.
I would be against lam in the entry, but then again, I live in Alaska.
Vinyl or tile for sure.
mdlbldrmatt135 12-27-2006 10:11 PM
I finally convinced her..... LOL Tile it will be,...... (Hopefully somethin' Stock...LOL
