Laminate Plank Installation With Minimum Waste - Flooring - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 10:17 AM   #1
Rewards Points: 276
Laminate plank installation with minimum waste
I am in the process of laying Pergo flooring. I seem to be wasting a lot. I have tried using the cut piece to start the next row as suggested but then I com up about 2-3 inches short on the other end. Any suggestions
Jim F is offline   Reply With Quote
Old 07-04-2012, 10:32 AM   #2
Rewards Points: 528
Cut the piece at the start so you have a larger piece to end with.
Didn't you figure on about 10% waste factor when you bought?
framer52 is offline   Reply With Quote
Old 07-04-2012, 11:38 AM   #3
Rewards Points: 276
Didn't you figure on about 10% waste factor when you bought?[/QUOTE]I did but I figure I'm wasting more than 10%.
Old 07-04-2012, 12:15 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Make shore you stagger your seams 12" apart.
You bought what you measured you won't have much waist at the end.
JetSwet is offline   Reply With Quote
Old 07-04-2012, 12:27 PM   #5
Rewards Points: 2,212
Take a measurement of the length of a run.
Take the measurement of each piece.
Calculate to stagger joints at least 12" (or whatever is recommended by manufacturer).
Should be able to use cut piece to start next row.
mae-ling is offline   Reply With Quote
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
Replacing Damage Planks in Laminate Floors manoa115 Flooring 1 09-18-2008 05:56 AM
Mix plank and tiles in laminate floors. sgbotsford Flooring 2 09-05-2008 02:51 PM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 01:24 AM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
