-   -   Laminate plank installation with minimum waste (http://www.diychatroom.com/f5/laminate-plank-installation-minimum-waste-149139/)
Jim F 07-04-2012 10:17 AM
I am in the process of laying Pergo flooring. I seem to be wasting a lot. I have tried using the cut piece to start the next row as suggested but then I com up about 2-3 inches short on the other end. Any suggestions
framer52 07-04-2012 10:32 AM
Cut the piece at the start so you have a larger piece to end with.
Didn't you figure on about 10% waste factor when you bought?
Jim F 07-04-2012 11:38 AM
Didn't you figure on about 10% waste factor when you bought?[/QUOTE]I did but I figure I'm wasting more than 10%.
JetSwet 07-04-2012 12:15 PM
Make shore you stagger your seams 12" apart.
You bought what you measured you won't have much waist at the end.
mae-ling 07-04-2012 12:27 PM
Take a measurement of the length of a run.
Take the measurement of each piece.
Calculate to stagger joints at least 12" (or whatever is recommended by manufacturer).
Should be able to use cut piece to start next row.
