Laminate Plank Install Help - Flooring - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 09:46 AM   #1
I am installing my laminate planks, and have made it to an area where there is approximately a 8"x16" .25-.5" drop. My question is what can I do to that area that will make it more level? I am installing them on the padding, which I just laid on the existing vinyl floor. This area is where an 18" pantry door is. It's high on the outside, slopes down through the doorway, then back up level once you get in the pantry. My dad said cut a piece of plywood that would raise that area up enough to make it more level than it is, and then fill some of the edge in with some excess padding. This is not going to be a high traffic area, but I just want to be sure that my planks will stay connected, whereas they won't now with the current drop.
ws450r is offline   Reply With Quote
Old 09-08-2011, 09:53 AM   #2
build the low area up with layers of cheap 12x12 fllor tiles or tar paper,feather area out to level,place below padding
Marbledust is offline   Reply With Quote
Old 09-08-2011, 10:07 AM   #3
What about using the padding I am laying my floor on to build it up? I have plenty extra.
Old 09-08-2011, 10:14 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh sure!!! I'm sure we all have "cheap 12X12 floor tiles" and "tar paper" laying around the house all the time. I keep mine in the kitchen pantry for quick access.
ws,
Too much padding will mean too much cush and the planks will probably come apart when walked on. Try filling the low area with floor patch.
XXX
Old 09-08-2011, 10:18 AM   #5
Originally Posted by Bud Cline View Post
ws,
Will that stuff bond to vinyl? Or would I need to take the vinyl off that area to get to the plywood subfloor?
Old 09-08-2011, 10:23 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use "Embossing Leveller" it will bond to vinyl.
XXX
Old 09-08-2011, 10:32 AM   #7
What is the process before I put that on the floor? Will I need to build an area to pour it in, and seal everything so it doesn't leak between the wall and floor? I already cut my door jambs, so I've got some space under tham that this stuff could get to.
Old 09-08-2011, 10:42 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You are making this way too difficult.
Embossing leveller comes in a dry powder that you mix with water and spread with a trowel. Put it where you want it.
XXX
Old 09-08-2011, 11:00 AM   #9
Oh, I was assuming it was like a liquid that you see those guys put down on the DIY Network when leveling out an area on a concrete floor, and the stuff goes everywhere.
And you're right. I probably am making this way to difficult.
Old 09-08-2011, 11:04 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You have to be carefull if you are going to consume DIY Network TV, it will get you into trouble.
XXX
Old 09-08-2011, 11:24 AM   #11
Lol. Luckily I don't get it with my Dish package, and only watch it when I go visit my parents a couple times a month. Otherwise, I might be going crazier than I am now wondering what to do. Guess that's why I check out this forum.
Old 09-09-2011, 12:46 PM   #12
ws,
Gee Bud...it may take a trip to the store?
do you stock floor level products,or do you buy it at the store?
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Laminate Install Question margog85 Flooring 2 03-20-2011 05:18 PM
hardie plank install questions Gnfanatic Building & Construction 12 10-30-2009 10:19 AM
Laminate flooring install questions wilderstyle Flooring 2 02-19-2009 04:45 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
