Laminate (pergo) In A Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 05:29 PM   #1
laminate (pergo) in a bathroom
earlier post got me thinking...is it ok to put this stuff in a bathroom? If it needs to "float",doesn't the toilet bolted down restrict that ?Also, is material dense enough to where it will not compress under the weight of the toilet? I would think if this happens, the toilet will loosen over time causing wax ring seal to fail,resulting in a leak. You guys have any thoughts?
johnrem is offline   Reply With Quote
Old 02-18-2008, 08:04 PM   #2
Rewards Points: 150
Its just not a good idea. The stuff doesnt handle moisture well at all and a standard toilet creats plenty of that
mike costello is offline   Reply With Quote
Old 02-18-2008, 08:34 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I would not recommend installing it in a bathroom. However, it has been done. In fact, we have installed, per request by Home Owner, in bathrooms. Tho, we will not warranty the installation.
Here is the Pergo Link regarding installation instructions. There is a section on Bathroom installation: http://www.pergo.com/images/pdfs/Install_Essentials.pdf
- Build Well -
Old 02-19-2008, 02:15 PM   #4
electrical contractor
Rewards Points: 150
DONT do it, Listen to the voice of experience. Pergo is not good with any moisture, and as mike pointed out there is plenty of that in a bathroom. All it takes is one overflowing toilet to get water in the joints between planks and swell the particleboard backing. You can get the water off the top but not from in the joints. My floor was the original Pergo that you had to glue together, if the glue didnt seal the joint the snap lock has no chance.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-19-2008, 09:49 PM   #5
Floorwizard's Avatar
it's a risk for sure.
go with Vinyl or Ceramic if moisture is the biggest concern.
Floorwizard is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Wanted: Pergo Paradigm laminate flooring PG 7005 Ivory Sandstone ridgebluff General DIY Discussions 6 05-30-2008 03:03 PM
Pergo Signature American Cottage Glueless Laminate saltwater Flooring 1 11-26-2007 06:32 PM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 12:02 PM
