Laminate Over Uneven Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 07:02 PM   #1
laminate over uneven subfloor
My dining room in my 65 year old house has a pretty uneven floor (existing hardwood). Within a 5 foot space, there is a 3/4 inch difference. Seeing how laminate is not nailed down, is this room even a candidate for laminate? I've read of using shingles as shims, but with THAT much of a slope?
smawgunner is offline   Reply With Quote
Old 09-24-2012, 07:08 PM   #2
Rewards Points: 13,694
Not going to work.
In fact any type flooring other then carpet most likly will not work.
Why not take the time to address what the issues are with the subfloor or floor joist then any type flooring will work and look better?
Old 09-24-2012, 07:14 PM   #3
You're probably right. Of course not the answer I was hoping for. But yeah, I'll most likely end up taking it down to the joists and shim or shore them up. This is in the corner of the room which is above the bottom of the basement stairs. In reality,..it could use a basement floor jack. But then I'm cranking the thing up a 1/4 inch every year or something silly.
Laminate floor subfloor not level Jarrod23 Flooring 2 02-11-2011 02:40 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
laminate floor vs subfloor 4 railing mount gdub Flooring 4 01-04-2008 02:42 PM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 04:01 PM
