Old 09-12-2006, 09:19 PM   #1
Laminate over linoleum?
Any experiences or knowledge appreciated!
FindingNemo is offline   Reply With Quote
Old 09-13-2006, 12:12 AM   #2
Floorwizard's Avatar
Completely acceptable.
make sure the floor is flat and level according to manufacturers specs.
Floorwizard is offline   Reply With Quote
Old 09-13-2006, 12:18 AM   #3
My only concern was that there was carpet to linoluem transition in the same room. By removing the carpet will that height difference of the linoleum be an issue?
Thanks for the info
Old 09-15-2006, 12:25 AM   #4
Question
Can I build up the hight difference with a high density particle board, or what would be the best to use for that I am gussing that the difference will be about 3/16" to A 1/4" when I remove the carpet.
The house is aprox 3 to 5 years old. I am worried that the lino will be allmost impossible to remove, being fairly new construction please help
Old 09-15-2006, 11:08 PM   #5
when you install the lam, it sounds like it will be of close height to the Vinyl.
A t-molding is then used.
Old 09-16-2006, 01:42 AM   #6
Sorry , I am installing a laminate flooring over the existing linoleum, and where the carpet is comming out. (hope to). But when I remove the carpet, there will be a height difference between where the carpet was, and where the linoleum is. This transition is in the same room/open space (not a doorway).
So I figure that the height difference between where the carpet was and the linoleum is will be about 3/16" - 1/4"
What would you do here? Would you spend the countless hours trying to remove the linoleum, or would you build up the floor where the carpet was?
Any suggestions are greatly appreciated. Sorry for the confusion.
Old 09-20-2006, 12:27 AM   #7
Depends on the sizes of the room and what is under the lino.
which would be smallest? the square footage of lino to remove or the square footage of underlay to install?
if you add underlay, will it affect any other areas for heighth?
Removing Vinyl and underlay can be a disaster especially if installed on particle board, or happens to be glued down.
you could also use a reducer that transitions down 1/4 inch or so, but wouldn't that look odd in the middle of a room?
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
Linoleum Finish Question scubasteve882001 Flooring 1 02-12-2007 08:55 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
