Old 09-06-2007, 03:59 PM   #1
Default Laminate Over Carpet
Hi, I need to know if I can lay a laminate floor over capet that is glued to a concrete slab. The floor would be used for a practice floor for an Irish Dancer. I would rather leave the carpet down to provide a sort of padding under the laminate. The house is a raised ranch that is about 10 years old, I have lived in it since new (and knock on wood) I have never had any moisture problems. The room is in the basement just off the garage. Also would anyone Know of any thing beside the carpeting I could put under the laminate to try and soften the floor a little? Thanks.
JoeyJet is offline   Reply With Quote
Old 09-06-2007, 04:17 PM   #2
I guess it depends on how bouncy your carpet, i.e. how high/low...etc... ...etc... personally... I don't see why not if there is no moisture/mold problem... that save you the disposal headache... . you may want to try out on a small area to see how it feel first...
KUIPORNG is offline   Reply With Quote
Old 09-06-2007, 06:27 PM   #3
Home Improvement Guy
ron schenker's Avatar
Never, ever put laminate over carpet regardless of thickness. It will all come apart at the seams. You have to remove the carpet and underpad, make sure the concrete is smooth and clean, then install the proper laminate underpad then the laminate wood floor.
ron schenker is offline   Reply With Quote
Old 09-07-2007, 07:57 AM   #4
poppameth
Guest
Posts: n/a
Seen it done over low nap commercial several times. Never seen a problem with it. Armstrong actually told me it was fine to put theirs over a low pile commercial. They said it voids the warranty to not use their pad but they had known people to do this before and never heard of any problems relating to it either.
Old 09-07-2007, 09:50 AM   #5
I am hoping this might work then. The carpet is a commercial type, very low pile. I really don't want to remove it because I hope it will give the floor some cushion because I am afraid that the laminate over the concrete alone will be to hard on the dancers knees. I guess I will give it a try and I'll let everyone know how it works out. Thanks for the input.
P.S. J-E-T-S JETS JETS JETS
Old 09-07-2007, 11:43 AM   #6
the quality of the laminate also very important... don't buy cheap stuff... cheap stuff requires 100% level otherwise will split....
best is buy one box, try it out, see if it is easy to install and not spliting easily... otherwise, put it back and refund for a good quality one...
stay with brand establish for a long time rather than those come from no where materials...
Old 12-13-2007, 03:32 PM   #7
I put the "why?!" in DIY
I realize this thread is 3 months old, but i thought I'd confirm that Armstrong does indeed say that their laminates can be installed over carpet as long as it is 1/4" or less, and adhered/level to a
wood subfloor. They also require a moisture barrier over the carpet. It would seem that since these instructions exist in their installation guide this would not void the warranty, but I would get that in writing first! Here's a link to some info:
http://www.floorexpert.com/Armstrong...2?OpenDocument
I'm considering this option with a room in my house that has very low pile commercial carpet installed over a wood subfloor. The only other option is to rip up the carpet and replace or sand all the subfloor...but if Armstrong says it is within "the rules", then I'll give it a shot. As I said, I'm going to get it in writing so if it does go bad I can make a warranty case.
jmancine is offline   Reply With Quote
Old 12-13-2007, 04:04 PM   #8
"They said it voids the waranty"
Theres a great reason not too right there.
Rip up the rug, use an approved undelay. For the little time and money you will be covered if anything happens
mike costello is offline   Reply With Quote
Old 12-13-2007, 04:12 PM   #9
another reason for wipping the carpet is with all the height lost, moisture barrier...etc.... your door may need to cut a lot...
you probably don't need to sand the wood subflooring as minor irregularity will be made up by a good quality underlayment....
More On This Topic
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
If you have old, aluminum frame windows in your home, you might be feeling the winter chill more severely. Swap out your windows for more modern ones and enjoy a cozy winter. Read on to learn more. Read More »
The last what you need to think about is fire safety. I am here with my best friend Red Bull. We would like to tell you a little about what you need to do with the fire. At night before you go to bed, you need to put this gate and close it right here... Read More »
Hi I am David Belch and I am here with Expert Village today to show you how to install windows. Right now we are going to talk about preparing the opening. I have got it completely out. I have removed any debris, any nails that might be in the way of... Read More »
Many people are choosing wood flooring for their homes. This type of flooring is durable, easy to take care of and pleasing to the eye. There a two basic kinds of wood flooring: hardwood and laminate. Choosing the right wood flooring will add value to a... Read More »
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 09:48 PM
Carpet and laminate sale - Lakewood, NJ Jeekinz Flooring 2 08-25-2007 09:37 AM
carpet vs. laminate?????? oblesq Flooring 15 07-31-2007 01:32 AM
Carpet vs Laminate and Vinyl vs Ceramic Kaminberry Flooring 5 02-26-2007 09:03 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 10:43 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
