Laminate Moulding - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 11:46 AM   #1
Rewards Points: 22
laminate moulding
Hi everyone.
Should i install what kind of molding in the gap between the floor and the sliding door ?
thanks for your time
pavlito24 is offline   Reply With Quote
Old 01-08-2015, 11:55 AM   #2
Rewards Points: 1,248
laminate moulding
Should have had a pan under it when it was installed.As far as trim molding on the inside .Shoe,quarterround or whatever will fit.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
pavlito24 (01-08-2015)
Old 01-08-2015, 12:38 PM   #3
Rewards Points: 22
laminate moulding
thanks you for the answer. but what means a pan under the laminate?
Old 01-08-2015, 12:57 PM   #4
Rewards Points: 1,298
laminate moulding
A sill pan under the door, not the laminate.
It keeps the water from getting in under the door and destroying the subfloor and flooring.
Google "jam sill"
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Unfinished moulding on laminate Hobby Haven Flooring 1 09-02-2009 07:06 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate and molding john1529 Flooring 5 04-25-2005 11:35 AM
