Laminate And Molding - Flooring - DIY Chatroom Home Improvement Forum
Old 04-20-2005, 11:54 AM   #1
Rewards Points: 24
Laminate and moulding
I installed laminate flooring in a dry area and need to install quarter round. I know the floor must be able to expand and contract. I notice that the laminate near the walls will move up and down slightly when walked on. Is it ok to push the quarter round down to hold the laminate down and nail the moulding to the wall? Can this harm the laminate by preventing movement? It seems like it would still be able to move back and forth similar to if it had a heavy object on it.
John
john1529 is offline   Reply With Quote
Old 04-20-2005, 06:17 PM   #2
pro flooring installer
Send a message via AIM to floorman Send a message via Yahoo to floorman
It would be o.k.to do as you said.As long as you do not nail through the laminate and nail it to the floor then you are good to go
floorman is offline   Reply With Quote
Old 04-22-2005, 08:25 PM   #3
Floorwizard's Avatar
I concur.
but the question is why it is bowing....
Floorwizard is offline   Reply With Quote
Old 04-23-2005, 10:16 AM   #4
Contractor
I'm guessing that the undrlay is compressing.
Teetorbilt is offline   Reply With Quote
Old 04-23-2005, 12:41 PM   #5
Send a message via MSN to Benhamcarpetguy
Was the floor installed to manufacturer's tolerances? If the substrate has deviations in flatness beyond the (usually)3/16 inch and you'll get that "springboard" effect. Forcing it down at the perimeter will only put the pressure in another location. Constant flex will break your tongue and the floor will fail.
But to your actual question, no, holding it down with 1/4 round won't restrict expansion/contraction as long as you don't nail through the floor.
Don
Benhamcarpetguy is offline   Reply With Quote
Old 04-25-2005, 10:35 AM   #6
Rewards Points: 24
Thanks for the responses. There was just a little noise from the underlayment rubbing along the side of the baseboard. This worked great. Thanks again!
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 09:57 PM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Laminate in Kitchen - Q & A - 101 allen1466 Flooring 6 07-09-2007 02:36 PM
Quarter Round Shoe - Dupont RealTouch Laminate tk3 Flooring 3 07-09-2007 11:12 AM
Joining laminate floors of different height. flyingmachine Flooring 5 09-13-2006 08:59 PM
