Old 10-07-2006, 06:34 PM   #1
Laminate Moisture Barrier
I have a "Florida room" that was walled in by the previous owner and tiled; however the floor is about 2.5" below the rest of the house. I want to install a wooden subfloor to raise it up and then install laminate over that.
Here's the question: do I need to put down vapor block sheeting over the tile before installing the wooden subfloor and laminate?
Redleg is offline   Reply With Quote
Old 10-07-2006, 09:03 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, you should. Moisture is the number one enemy of wood and laminate flooring.
- Build Well -
Old 10-13-2006, 07:58 PM   #3
Got it, thanks!
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
moisture behind vapour barrier piperboy General Discussion 9 10-21-2008 01:49 PM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
moisture barrier? rondo Flooring 3 09-13-2006 09:51 AM
