-   -   Laminate Moisture Barrier (http://www.diychatroom.com/f5/laminate-moisture-barrier-4243/)
Redleg 10-07-2006 05:34 PM
I have a "Florida room" that was walled in by the previous owner and tiled; however the floor is about 2.5" below the rest of the house. I want to install a wooden subfloor to raise it up and then install laminate over that.
Here's the question: do I need to put down vapor block sheeting over the tile before installing the wooden subfloor and laminate?
AtlanticWBConst. 10-07-2006 08:03 PM
Yes, you should. Moisture is the number one enemy of wood and laminate flooring.
Redleg 10-13-2006 06:58 PM
Got it, thanks!
