-   -   LAMINATE: liquid nails (http://www.diychatroom.com/f5/laminate-liquid-nails-24367/)
nathan.tran 07-28-2008 02:20 AM
I will have several transitions from laminate floor on concrete subfloor to tile (reducer), wood (T-molding) fireplace (end-cap). The prospect of drilling concrete floor to put in the u-track of the transition is not very thrilling. I have failed terribly before when putting in molding between carpet and tile floor. I broke several drill bits and gave up.
I just found out from an old post in this forum that you can use liquil nail to fasten the u-track to concrete floor (:thumbup: ) Well, liquid nail website shows a total of 60 adhesives, probably with a devious purpose of confusing novice like me. :confused1:
In short, which liquid nails should I use for u-track transition strip ?
Nathan
HomeDepot23 07-28-2008 05:09 PM
I have found that liquid nails holds too well. It doesn't allow for movement when somebody walks across the threshold. The tracks give just a bit.
Instead, use G.E. windows and doors silicon II. Use blue tape to hold it in place until it sets. You will fell a little give, but it works well.
nathan.tran 07-28-2008 05:26 PM
Thanks for the tip. Isn't GE silicon II a sealant ? How would it hold compare to an adhesive ?
Nathan
HomeDepot23 07-28-2008 05:33 PM
You are correct. But it works great. Like I said, it does allow for a little movement.
