Laminate Lines Not Straight... - Flooring - DIY Chatroom Home Improvement Forum
Old 08-24-2006, 12:24 PM   #1
Rewards Points: 79
Unhappy
Just had the 3.25" wide 8mm laminate flooring (with micro groove edges) installed in a room 20 x 25 feet wide. In the center of the room the lines between the boards looks curved. Sure enough, put a line on it and it is out about 3/8" in 20 feet. Is this an installation problem or can it be expected that this flooring could be "curved" in a large room? Looking for advice. Several visitors have already pointed this out...which doesn't really make us too happy...cause this stuff was more than half the price of real hardwood. Thanks!!
sootybuttercup is offline   Reply With Quote
Old 08-24-2006, 05:37 PM   #2
Master Craftsman
Big Dave's Avatar
I am guessing that it is nail down flooring. If it is, it is an installation problem. I have never seen click together flooring curve. Did you install or did you have someone else do it?
Dave.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 08-24-2006, 11:40 PM   #3
Middle aged floor guy
Donedat's Avatar
Is it laminate or engineered flooring????
Donedat is offline   Reply With Quote
Old 08-25-2006, 12:22 PM   #4
Rewards Points: 79
It's "Tarkett Occasions" laminate with the good black underpad...not nailed....and was installed by a flooring contractor.
Old 08-25-2006, 03:11 PM   #5
do you have a photo?
redline is offline   Reply With Quote
Old 08-25-2006, 05:47 PM   #6
Rewards Points: 79
Exclamation
Worth 2000 words?
One pic shows the end view...kindof hard to see curve in the pic. The top view pic with the string has the string held on the line at the 16 foot wide end of the room (at stairway opening). The string is on the groove between the boards at each and...and as the pic shows, the curve is about 1/4" off at its worst in this 16 foot run.
Laminate Lines Not Straight...-img_0307.jpg   Laminate Lines Not Straight...-img_0311.jpg
Old 08-30-2006, 12:53 AM   #7
Floorwizard's Avatar
That is odd.
If it was bad milling, then the 2 pieces would have to be curved for it to work.
Is it bowing up at all or just to the left or right?
I am not sure how laminate can curve left or right.
Floorwizard is offline   Reply With Quote
Old 09-01-2006, 03:32 AM   #8
Rewards Points: 79
not bowing up...just curving along the length of the room...the whole floor is like this
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
