Laminate - Last Row, Minimum Width??? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 02:56 AM   #1
Laminate - Last row, minimum width???
I am installing a laminate floor with 7.5" planks. The various walls are laid out so that there is no way to make nice thick edge pieces. If I make a 3" end piece on one wall, it will end up being 1.5" in another room or hallway. There's just no way to get around there being a thin ending plank somewhere.
My question is, is it ok to have your end piece as thin as 1.5" - 2" in some areas? Obviously the bigger the better, but this is my first flooring project and I can't find a solid answer as to what is too thin for the last plank.
Thank you guys in advance. I'm going to catch some zzz's and get back at this in the morning.
jesse75 is offline   Reply With Quote
Old 07-10-2013, 01:43 AM   #2
Better to have even sized end pieces for a nicer look, even though its just 2 inches. It shouldn't be 2 inches in one end and 4 in the other. Maybe you need some more adjustment while laying.
AbbeyCarpet is offline   Reply With Quote
Old 07-10-2013, 05:43 PM   #3
the size of a piece in one room should have no effect on the length of a piece in another room. a drawing or picture would help. you can adjust the length of the end piece by varying the length of the starter piece in that row. or are you talking about the long thin pieces in the last row?
Old 07-11-2013, 06:50 PM   #4
I take it that you are running all the laminate through the rooms in one without transitions strips?
midnightfox is offline   Reply With Quote
Old 07-11-2013, 08:56 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Might be able to strip down the 1st board then move the entire floor down so the last will be thicker.
Read the recommendations on how far you can lay the laminate before it needs a transition strip.
Offset your seams a good 12" apart.
JetSwet is offline   Reply With Quote
minimum width for a piece between two outlets amakarevic Electrical 3 10-22-2012 07:59 AM
removing wall, can I patch laminate floor to connect 2 laminate floors? tworicks Building & Construction 2 01-21-2012 05:47 PM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 05:05 PM
where to find narrow plank width laminate pamelajosmith Flooring 2 03-13-2011 11:58 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
