Old 12-17-2006, 05:37 PM   #1
Laminate Kitchen Floor
I am getting ready to embark on a kitchen remodeling project and have a question about the flooring.
We are going to remove the cabinets and install new, and while the cabinets are out, I would like to replace the floor. I am considering a wood grained laminate and would like to lay it wall to wall, with the cabinets on top of the laminate. Is this possible, or will I have problems down the road.
Thanks for all answers!
Rawhide is offline   Reply With Quote
Old 12-18-2006, 11:30 PM   #2
Log-Style Home Contractor
North Country's Avatar
While it is possible to set cabinets on a floating floor, it isn't advisable. (one of the flooring guys will be in to comment on this) It is always best to cut the area out a 1/4" larger than your cabinet footprint, so the floor can expand/contract properly.
North Country is offline   Reply With Quote
Old 12-19-2006, 10:36 PM   #3
Floorwizard's Avatar
yup. wait till the cabs are in. then you will buy less floor to install possibly.
unless the cabs are mounted to the wall, they cannot be screwed to the lam. the lam must remain a floating only floor.
Floorwizard is offline   Reply With Quote
Old 12-20-2006, 05:18 AM   #4
I am correct to assume then if I lay the flooring after the cabinets are installed, that the refrigerator and stove and sit on top of the laminate floor with no issues?
Old 12-27-2006, 01:42 PM   #5
that is correct.
Old 01-04-2007, 08:34 PM   #6
How about around the dishwasher?
We are thinking of installing laminate in our kitchen which just has vinyl flooring. We are not removing cabinets or anything. Do you just run the laminate in front of the dishwasher and install trim moulding to finish it off right there?
Jeff
Racer is offline   Reply With Quote
Old 01-05-2007, 03:07 PM   #7
I am getting ready to put laminate (pergo) in my kitchen adn was going to install it then put cabinets on top. Even if they are screwed into the wall and not the floor it is still wise not to sit it on top of the laminate?
brtims is offline   Reply With Quote
Old 01-05-2007, 06:09 PM   #8
Contractor
The base cabs need to be on something solid or you are going to have all kinds of problems. Is the Pergo water resistant? If not, you can expect to replace/repair it in the future and cutting under the toekicks can be a real challenge.
Teetorbilt is offline   Reply With Quote
Old 01-05-2007, 07:52 PM   #9
to avoid future nightmares I guess it is better to put cabinets down first then the floor. You are right cutting through it later would be ugly if I had to reapir it. they are waterproof but who knows how good
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
laminate floor in Kitchen yellow.shoes General Discussion 6 02-28-2009 12:36 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 11:44 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
