Laminate Install Question - Flooring - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 06:40 PM   #1
When I put down the base moldings and quarter rounds along the perimeter of the room, do I put it down tight to the floor or leave some space?
margog85 is offline   Reply With Quote
Old 01-04-2010, 12:30 AM   #2
Hi, I do flooring for a living. Make sure you have a quarter inch gap around the perimiter, and then you can put down the base a shoe mold/quarter round down. You can set it on the floor. A gap between the trim and floor is not required. The floor will still float. Just don't force the trim down real tight. The sub floor should be pretty level if prepped right. Hope this helps you. Tony
sourek is offline   Reply With Quote
Old 03-20-2011, 05:18 PM   #3
put the base tight to the floor.. do you want a gap to show? nope.
IceT is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
culture stone install question raven27 Building & Construction 4 11-02-2009 11:31 AM
laminate floor install hiccup.. help! drewdc Flooring 2 03-30-2008 10:45 PM
Yet another question about Laminate loomis1228 Flooring 4 10-09-2007 08:31 PM
