Laminate Or Hardwood In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 05:51 PM   #1
laminate or hardwood in basement
I'm looking for a little guidance on choosing hardwood or laminate for my basement. It's dry and I haven't had any moisture. I also want to use the thickest option possible to bring flooring even or close to even with carpet. Lastly a step by step on installation would be much appreciated. It's obvious i'm not handy but would like to try it. Thanks!
dfarago is offline   Reply With Quote
Old 02-21-2012, 06:01 PM   #2
Rewards Points: 13,950
Neither, use engineered hardwood.
Laminite to me looks like plastic.
Hardwood can not be nailed down or glued down to concrete floor.
Engineered hard wood is real wood attached to plywood. It's far more stable. can be bought up to 3/4" thick, can be refinished, has a super tough finish on it. It can be installed as a floating floor so there's no need to attach it directly to the concrete.
Your still going to need an underlayment. Cork works best.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
dfarago (02-22-2012), Edgar214 (02-21-2012)
Old 02-22-2012, 03:59 PM   #3
While I agree that an engineered hardwood would be the way to go should hardwood be selected as the material to go down in the basement, there are still a lot of laminates that have improved aesthetically over the years; many offer a very authentic, non-plastic appearance. That being said, although it was mentioned that moisture has not been an issue in your basement, should it ever be, many laminates have been constructed with moisture resistant technologies, e.g., Armstrong laminates offer the HydroCore, Shaw offers OptiCore, and Mannington uses a combination of aluminum-oxide and Teflon to ward off wear, tear, and water damage. All that said, there are a wide range of options whether you go with engineered hardwood or laminate, but definitely keep laminate on your radar unless you find an engineered hardwood that you can't live without; we've worked with many clients who, after years of having it down, are still thrilled with the laminates that have been put into their basements.
I hope this helps!
aaron_david is offline   Reply With Quote
Old 02-22-2012, 06:23 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
You can get 10mm or 12mm laminate the higher mm grade the less plastic/ cheap it will look the tougher and thicker it will look as well.
Sent from my iPhone 4 ios5
JetSwet is offline   Reply With Quote
Laminate floor in basement questions ryoung25 Flooring 8 09-15-2010 10:33 PM
Laminate in a basement danidisney Flooring 2 07-12-2008 07:26 PM
Laminate in Basement Question atilla137 Flooring 16 11-10-2007 07:44 PM
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 10:17 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 09:03 AM
