Laminate In Hallway: Last Row? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 08:29 AM   #1
Rewards Points: 1,050
Laminate in hallway: last row?
Hello
What is the best method to put laminate (quick lock type) into a hallway when it comes to install the last row regarding the doors?
I won’t be able to slide it under the door jamb and keep the angle to get it properly locked with the previous row
*) Should I cut the upper part of the groove, allowing to slide back the new row flat (without maintaining the angle), and in that case I will need to glue the seam?
*) Or is it better to remove the door trims?
*) Or is there another best option?
french_guy is offline   Reply With Quote
Old 04-22-2013, 09:26 AM   #2
woodman58's Avatar
The way you said will work fine. I normally shave the bottom of the groove and glue it. use enough glue so that it comes to the surface and wipe the excess off. Use blue tape to hold them together until glue sets up.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 04-22-2013, 06:54 PM   #3
blue tape is enough to maintain it with sufficient strength?
Old 04-23-2013, 07:02 PM   #4
woodman58's Avatar
YES it is enough
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Problem with laminate in hallway Hammerhands Flooring 4 09-23-2010 02:16 PM
Installing laminate down a hallway ? 6brnr Flooring 2 05-18-2010 02:33 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-17-2007 11:18 PM
