Laminate With Foam Pad On Top Of Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2014, 10:10 AM   #1
Rewards Points: 61
Question
Laminate with foam pad on top of underlayment?
As the title suggests, maybe an easy question but is there any reason to not lay laminate with attached pad on top of underlayment? I removed the laminate floor I had in a room due to a water leak. Now that I've found a replacment floor that has attached pad under it. Half the room still has a 2 in 1 underlayment & vapor barrier that wasn't damaged. I'm thinking should I remove that underlayment and place only a vapor barrier or just cover the rest of the room in the same 2 in 1 underlayment and place the new floor on top?
I'd hate to make a mistake that would cost me to have to pull up the floor at a later date to correct.
Thanks for your assistance.
aidan80 is offline   Reply With Quote
Old 03-04-2014, 05:53 PM   #2
Rewards Points: 18
No expert here, but I would remove the old underlayment and, if you need one (check your instructions) add a new vapor barrier.
If you leave the old stuff, the floor will be too mushy and bouncy, and the joints may eventually fail.
Jtom is offline   Reply With Quote
The Following User Says Thank You to Jtom For This Useful Post:
joecaption (03-04-2014)
Old 03-04-2014, 07:46 PM   #3
Rewards Points: 13,722
Jtom is right, it needs to go.
You saw how easy it was destroyed and you still want laminate?
Hmm.
What size plywood for laminate underlayment? ghutch Remodeling 1 12-16-2013 06:44 AM
Using an underlayment in addition to a pre-attached pad on laminate joeburke Flooring 2 08-23-2012 12:14 PM
Laminate Flooring - underlayment poconosms1 Flooring 3 02-21-2012 10:03 AM
Eng H/W install - foam or felt underlayment? raylo32 Flooring 0 05-12-2010 12:25 PM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 04:09 AM
