Laminate Floorinig Install Question - Flooring - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 10:46 AM   #1
Exclamation
Laminate floorinig install question
Hello everyone..
I need your advice/help with my install. I just finished my basement reno and I'm ready for the flooring. I'm going to be laying down DriCore as a subfloor on top of concrete. I'm also going to be putting down a 12mm commercial grade (AC5) laminate floor by Kronotex.
My concern is this. The area of coverage is "t" shaped, whereby the top of the T is approx. 45x15 and the stem of the T is approx. 30x20. Should I be using a transitional piece (T-moulding) or should I just lay the flooring all in one direction???
Please advise.......
I've uploaded a drawing in PDF if that helps
File Type: pdf Rough Drawing of Basement with measurements.pdf (14.0 KB, 63 views)
Sunnybono is offline   Reply With Quote
Old 08-29-2013, 05:19 PM   #2
Rewards Points: 3,130
I think it's more a matter of how you want the floor to look than anything else. I'd try laying out a few pieces in each pattern and see which you prefer.
The Following User Says Thank You to md2lgyk For This Useful Post:
Sunnybono (09-02-2013)
Old 08-29-2013, 06:52 PM   #3
Rewards Points: 4,792
I agree with md. I'd probably lay it with the boards aligned lengthwise down the base of the T and no transitions.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 09-01-2013, 08:17 PM   #4
Retired & Not Likin' It
Jim McClain's Avatar
Some laminate flooring is not intended to cover spans that large without a break, like "T" molding that allows for an expansion gap under it. Check with Kronotex to see if that is explained in their installation literature, or if you need to contact them to clarify that issue. http://kronotexusa.com/installation/
In my opinion, a continuous floor, laid in one direction, tends to make a space look larger and more open. But there are times that it can be more aesthetically pleasing to change directions. You might try some mock layouts to see what looks best for your place.
Jim
Jim McClain is offline   Reply With Quote
The Following User Says Thank You to Jim McClain For This Useful Post:
Old 09-01-2013, 09:50 PM   #5
+1 to that.
Old 09-02-2013, 05:53 PM   #6
Thank you everyone who has responded. I spoke to the distributor and he said that it was not necessary to add a tansition piece.
However here is my new question. What are installers using as laminate cutters?? I plan on using a skill saw and table saw but i was thinking about saving all that dust from flying
Old 09-02-2013, 07:07 PM   #7
I never met a distributor, in my 35 years of flooring experience, that I could trust to know about every product they distribute. Why not contact the manufacturer and see what they advise?
Laminate sawdust is pretty noxious. I used a laminate cutter. You can get them at your distributor, prob'ly, or ebay: http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40 Use it, then sell it back on ebay.
Jim
Old 09-02-2013, 07:10 PM   #8
I prefer laminates in the thicker range - 12-15mm. Do those laminate cutters work on the thicker sizes?
Old 09-02-2013, 07:30 PM   #9
There is a laminate cutter that will work on all thicknesses of material. You have to decide what you want to budget for tools and find the tool that works in your budget. If you were a pro, you might not blink at spending nearly a tousand bucks for the right tool. I don't know what a DIYer would blink at. The link I shared has some for as little as 20 bucks, but I've got no idea what their limitations are. Mine cut through anything I put in its throat, but I spent over $600.00 on it. I didn't get near that when I sold it after I retired.
Jim
Old 09-02-2013, 07:34 PM   #10
Jim
You're absolutely correct Jim. I've already emailed Kronotex USA for their advice. I'm hoping they will help out even though they do not sell the Mammut AC5 line in the States.
I like the laminate cutter that you recommended. Do you know of a store in the GTA (Toronto area) that carries this unit?? The store on Ebay from Nova Scotia wants $125 + $40 for shipping.
Old 09-02-2013, 07:36 PM   #11
Jim
Correct, i think price will dictate in this product..
Old 09-02-2013, 07:48 PM   #12
The King Canada tool that Jim has recommended cuts 19/32" thus its cuts greater than 12mm which is 1/2" but to be exact it should cut 15mm but no greater.....
Old 09-02-2013, 08:11 PM   #13
The King Canada tool that Jim has recommended...
Am I missing something here? I did NOT recommend any brand of laminate cutter. The link I provided goes to an ebay page that lists everything using the "laminate flooring cutter" search term. There's a whole bunch of them on that page, none of which are tools I would specifically recommend because I am not familiar with them. I was just suggesting resources, not actual products. If I was asked to recommend a cutter to a pro, I would send them here: http://www.bullettools.com/flooring/...ooring-cutters I would not recommend a DIYer spend that kind of money on a single project.
Jim
Old 09-02-2013, 08:14 PM   #14
Jim
Sorry Jim, I thought you were recommending the King Canada product on the Ebay page as it appeared as the 1st product on the page.
Tags
ac5 , dricore , kronotex , laminate floor , transition moldings
Laminate Install Question StuartT Flooring 9 01-25-2013 10:14 PM
laminate v. door jamb question rookiework Flooring 3 10-10-2012 08:57 PM
Ready to lay laminate... Question... KUIPORNG Flooring 6 04-13-2007 03:17 PM
Laminate Selection & Install Question sdcards Flooring 1 10-13-2005 05:12 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
