Laminate Flooring On Walls (Bathroom) - Flooring - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 12:21 AM   #1
How does this work? I've searched endlessly only to find a couple sites saying they are to be attached with nails, right against the wall. But what about the expansion of the wood? I'm especially concerned because it's in a bathroom.
I'm looking to do something similar to the below picture in my bathroom as a feature wall
Should I look for some type of paneling and cut it myself instead of laminate floors?
Toilet Bowl is offline   Reply With Quote
Old 06-08-2012, 08:54 AM   #2
Bill Kearney
Rewards Points: 1,174
Properly vented, there's not much reason for a bathroom to be any more humid than your other rooms. But lots of people fail to properly vent the space, thus the humidity issues. One sure way to make sure the fan runs is to connect it to the same switch as the light (assuming it's not a dimmer, of course). But that's potentially problematic in that you want the fan to stay running for a while after you're done, to thoroughly vent the space. Lutron makes a handy combo timer/dimmer switch that's good for this.
wkearney99 is offline   Reply With Quote
Old 06-08-2012, 12:22 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
Bad idea. Wasn't intended for walls. It will buckle.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-08-2012, 10:17 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
I don't think that's laminate in that photo.
There right laminate will not work as it is a floating floor.
The only thing I can think of is if you insist on using laminate like this is to keep a space between the plank and liquid nail them to the wall, but may and I mean may not work.
JetSwet is offline   Reply With Quote
Old 06-08-2012, 10:37 PM   #5
thanks for the clarification. I definitely wont be using laminate
but how would I achieve something like this?
Old 06-08-2012, 11:10 PM   #6
Rewards Points: 38
That certainly doesn't look like laminate. Suppose it could be engineered.
Old 06-09-2012, 09:19 AM   #7
Rewards Points: 13,228
A prefinished engineered floor would work.
Since your putting it on a wall you could go with the thinner material since it will never need to be refinished like a floor would.
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
Need advice on what easy to install / inexpensive flooring options for bathroom floor amodoko Flooring 9 06-04-2011 05:23 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 01:02 PM
