Old 09-20-2012, 07:31 AM   #1
laminate flooring underlayment
I do not like the feeling of spongy feeling when walking on laminate flooring with foam underlayment and can not afford to install a real hardwood. So, ca I get away with just lay tar paper and install laminate over it if i make the floor as flat as possible? I would like to hear from someone who actually done it?
thanks for all the help.
bangan is offline   Reply With Quote
Old 09-20-2012, 09:53 AM   #2
it doesnt have to be foam, they make plastic underlayment, they make a black flat foam that isnt spongy. its a lot of work to replace it though. I am buying a laminate with attached underlayment pad
firsttimeremode is offline   Reply With Quote
Old 09-20-2012, 10:15 AM   #3
Tar paper is sticky and will cause the floor to pull apart.
As suggested a better grade will have the padding attached. Cork underlaymnet also works.
Old 09-20-2012, 10:13 PM   #4
JetSwet's Avatar
http://www.quietwalk.com/
Tarpaper is not a recommend vapor barroir.
JetSwet is offline   Reply With Quote
Old 09-22-2012, 08:32 PM   #5
Consider engineered wood flooring.
Laminate Floor Underlayment Question hurt138 Flooring 4 11-08-2011 01:30 PM
Laminate flooring - Question on Flooring Brand Locksley Flooring 3 09-09-2009 09:35 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 05:09 AM
