-   -   laminate flooring underlayment (http://www.diychatroom.com/f5/laminate-flooring-underlayment-157381/)
bangan 09-20-2012 07:31 AM
I do not like the feeling of spongy feeling when walking on laminate flooring with foam underlayment and can not afford to install a real hardwood. So, ca I get away with just lay tar paper and install laminate over it if i make the floor as flat as possible? I would like to hear from someone who actually done it?
thanks for all the help.
firsttimeremode 09-20-2012 09:53 AM
it doesnt have to be foam, they make plastic underlayment, they make a black flat foam that isnt spongy. its a lot of work to replace it though. I am buying a laminate with attached underlayment pad
joecaption 09-20-2012 10:15 AM
Tar paper is sticky and will cause the floor to pull apart.
As suggested a better grade will have the padding attached. Cork underlaymnet also works.
JetSwet 09-20-2012 10:13 PM
http://www.quietwalk.com/
Tarpaper is not a recommend vapor barroir.
ToolSeeker 09-22-2012 08:32 PM
Consider engineered wood flooring.
