Laminate Flooring Underlay - Flooring - DIY Chatroom Home Improvement Forum
Old 10-19-2014, 02:02 PM   #1
Rewards Points: 2
Laminate flooring underlay
Hi all,
I'm having the task to lay laminate flooring, but the unfortunate problem is there's carpet underlay glued to the floor boards.
This underlay is been down for years and is causing a lot of problems to remove, could I laminate on top or is this a big no no?
Sent from my iPad using Tapatalk
wxmnath is offline   Reply With Quote
Old 10-19-2014, 08:26 PM   #2
Plumber/Contractor
TheEplumber's Avatar
Rewards Points: 2,624
Thread moved to flooring
Old 10-19-2014, 10:45 PM   #3
Rewards Points: 606
Carpet pads to thick and not dense enough for laminate, it's got to go.
What are you using to remove it?
Old 10-20-2014, 04:39 PM   #4
Rewards Points: 2
Hand scraper and a lot of sore fingers! I'm trying to prize it off bit by bit. But it's pulling splinters out of the floor boards too.
Anything you recommend using?
Old 10-20-2014, 06:42 PM   #5
Rewards Points: 606
http://www.homedepot.com/p/Unbranded...-004/202357620
Laminate flooring underlay... BCSapper Flooring 5 11-11-2011 12:27 AM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 08:34 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
