Old 01-30-2007, 12:01 AM   #1
Default Laminate Flooring Transition Question
We'll be installing our Wilsonart laminate floor soon and I have a question regarding what type of transition to use for an adjoining floor that is higher than the laminate floor level. Our kitchen is ceramic tile that was applied to 1/2" plywood on top of the old floor level. This raises the kitchen floor up quite a bit.
I would like to use 6mm of cork, but that would void the manufacturer's warranty (I believe). Still need to call them to verify this. That would raise the floor level up enough so that the final level would be close enough to use a T-mold.
Seems like the reducer transitions are for the laminate floor being the higher level.
Did anyone have a similar situation and how did you resolve it?
Thanks for any suggestions!!
flysndoc is offline   Reply With Quote
Old 01-30-2007, 12:48 AM   #2
Super Moderator
Floorwizard's Avatar
yup, a reducer usually used to transition down to vinyl will be used except it will be installed flipped.
so it will go from the tile down to lam.
some trimming may be required.
Time to ride again!
Floorwizard is offline   Reply With Quote
More On This Topic
Sometimes we have trouble using verbs correctly in a sentence, particularly when writing. Since writing requires proper following of grammar rules, it’s easy to simply apply how we speak rather than taking the time to look for a correct answer. A... Read More »
Whether your style is country or cowboy, your kitchen is a great place to show off your personality. It's a gathering place for friends and family and should be comfortable and friendly to all who enter. The best way to do this is to create a rustic... Read More »
Hi! I’m William Myers with Subaru for Expert Village. We’ve checked your battery level, now if you had to add water to your battery all you would do is remove the cap and add your distilled water right in there. That’s how you would add... Read More »
On behalf of Expert Village, my name is Gilson "the Barbarian" Oliveira, speaking to you from Camp Undefeated in New York City, bringing to you today, practice drills for fighters. After you master and develop some good level of strength in your legs... Read More »
Keyboarding Tips
Keyboarding Tips by Expert Village
Hi, this is Linda Lewis on behalf of Expert Village.com. Check out my website at www.keytime.com. What are some secrets for typing at home? Often times when you want to go like to your kitchen table to check your e-mail, that you need to think about how... Read More »
Laminate Flooring Outdoors fogel1497 Flooring 1 05-28-2007 05:39 PM
Laminate Flooring Question MillerClemsonHD Flooring 4 02-17-2007 05:49 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 10:35 PM
Laminate Flooring Question cacell Flooring 6 03-03-2006 07:44 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 02:05 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
