Laminate Flooring Transition ? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 07:57 AM   #1
laminate flooring transition ?
I will be installing a laminate floor purchased from lumber liq it is the dream home nirvana 8mm with 3mm pad it will be installed in 3 bedrooms and a hallway my question in when i reach the doorways is it a must to use their t molding or transitions or can i just keep clicking the pieces together .Also were would the proper place to start the job be if the rooms run off both sides of the hallway . thanks
ants1929 is offline   Reply With Quote
Old 02-24-2011, 08:00 AM   #2
Coatings Nerd
I actually started in the hallways and did not use the transitions. It looks better IMO. Keep in mind that you will have to rip some pieces lengthwise, along some walls.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-24-2011, 08:05 AM   #3
Handyman
Rewards Points: 512
Its a neater job if you just continue the flooring through the doorways, provided the board orientation suits the room. Be sure to undercut the door jambs and casing to allow the floor to fit under them.
canadaclub is offline   Reply With Quote
Old 02-24-2011, 08:07 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
They tell you to use the transitions. Can you skip them, maybe? They want you to use them so the floating floor can expand and contract. So it may buckle without them. With LL poducts, I would do everything I could to avoid further problems.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-24-2011, 02:02 PM   #5
i have a tongue and groove pine subfloor the boards are 3" or just under 3" what would be the best way to level or flatten this floor.
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
laminate flooring - transition suncowiam Flooring 4 09-11-2009 10:37 AM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 10:48 PM
