Old 09-09-2009, 07:27 PM   #1
laminate flooring - transition
I just put in laminate flooring in my living room. I have moldings to transition to the kitchen and bathroom which are tiles, but I don't know how to transition to the front door and the screen door. I have base boards which will hide the little gap in between the walls but I don't know what to do with the front door and the screen door. How would I hide the gap for that?
Thanks in advance.
suncowiam is offline   Reply With Quote
Old 09-10-2009, 07:23 AM   #2
Quarter round or similar will usually work there. Laminates expand/contract much more than wood floors, so you still need that space, 1/4" more or less.
Old 09-10-2009, 01:35 PM   #3
I thought of using the quarter round, but several things:
* I would need to trim it in order to fit underneath front door base and the screen door base.
* And since this is a passageway, I'm concerned that people would step on it, therefore, breaking it off the wall.
Old 09-11-2009, 08:11 AM   #4
Silicone. Try to as closely as possible match color to either the flooring, or the bottom of the door. Silicone will still allow the laminate to expand & contract.
One thing I sometimes do when I've got a height issue on the door threshold is to cut a piece of wood about 1/4" thick & 3/4" wide. Lay it flat on the flooring, butted up against the threshold. Stain & finish it to match the flooring. You can use silicone to adhear it to the laminate.
pinwheel45 is offline   Reply With Quote
Old 09-11-2009, 11:37 AM   #5
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 11:48 PM
