-   -   laminate flooring - transition (http://www.diychatroom.com/f5/laminate-flooring-transition-52647/)
suncowiam 09-09-2009 07:27 PM
I just put in laminate flooring in my living room. I have moldings to transition to the kitchen and bathroom which are tiles, but I don't know how to transition to the front door and the screen door. I have base boards which will hide the little gap in between the walls but I don't know what to do with the front door and the screen door. How would I hide the gap for that?
Thanks in advance.
Just Bill 09-10-2009 07:23 AM
Quarter round or similar will usually work there. Laminates expand/contract much more than wood floors, so you still need that space, 1/4" more or less.
suncowiam 09-10-2009 01:35 PM
I thought of using the quarter round, but several things:
* I would need to trim it in order to fit underneath front door base and the screen door base.
* And since this is a passageway, I'm concerned that people would step on it, therefore, breaking it off the wall.
pinwheel45 09-11-2009 08:11 AM
Silicone. Try to as closely as possible match color to either the flooring, or the bottom of the door. Silicone will still allow the laminate to expand & contract.
One thing I sometimes do when I've got a height issue on the door threshold is to cut a piece of wood about 1/4" thick & 3/4" wide. Lay it flat on the flooring, butted up against the threshold. Stain & finish it to match the flooring. You can use silicone to adhear it to the laminate.
suncowiam 09-11-2009 11:37 AM
