Laminate flooring repairs
If this is glueless laminate flooring then it will come up the same way you put it down, find the place where you finished, lift off any trim or remove the skirting if you fitted it after. Now lift the length upwards and the laminate board will come away smoothly. To get down to individual boards just lift upwards and away from each other - this makes more sense when you do it!
If it is glued then your options are very limited and I'd be ringing the insurance company by now as the lot will need replacing, and as my excess is only £50 and am covered for accidents I'd let them sort it out.
If you are desperate to sort this out without doing the above then yes, some laminates can be sanded and varnished. If the board hasn't warped then this may be worth doing.
Do you have the type of board that has 5mm of solid wood on the top?
Cheers
