-   -   Laminate Flooring Questions (http://www.diychatroom.com/f5/laminate-flooring-questions-45399/)
middie 05-27-2009 05:38 PM
Hello!
I'm installing our laminate floor for the very first time and would like some help...
I've a bunch of questions (with pictures!), so please bear with me...
The first question is, we're going to laying the laminate over the existing linoleum, simply due to the difficulty it pulling up the old stuff. We've got the underlay, but is there anything else we need to know before going forward?
Second question (first picture!):
http://plofo.shutterfly.com/905
I assume we could just undercut the door frame here to install the floor? The piece to the left is quarter-round and will be removed..
Third question:
http://plofo.shutterfly.com/906
As you can see, the transition here is pretty ugly.. I assume we'd just pull up the gold piece and replace with the new transition piece, placing the carpet UNDER the one side of the piece?
Fourth question:
http://plofo.shutterfly.com/907
Any ideas on how to take these angles? We're going on a 45 degree angle from the gold trim (following the seams in the linoleum) towards the bottom right corner of the picture.
Fifth question:
http://plofo.shutterfly.com/902
http://plofo.shutterfly.com/904
As you can see, this section of floor is pretty beat up. It leads to the sliding door.. The linoleum is curled up and pretty damaged. I think we can probably screw it down to the wood that's there (or glue it) and just apply the laminate over top. The quarter round or a transition piece would be applied to the aluminum frame..
Thanks for the help in advance!!
Justin
Just Bill 05-28-2009 06:56 AM
If the old floor does not have loose material or bubbles, I would say it is OK to go over it with laminate.
Laminate flooring floats on the exisitng floor, so it has to be able to expand/contract, usually requires 1/4+". Fitting it tight to doorways may not be OK, check manufacturers directions.
The gold piece is a transition/tack strip for the carpet. If you remove it you need to install a tack strip to keep that edge tight.
Changing direction with laminate and have it look good over time is not easy. Consider keeping everything in one direction.
Cut off all curled vinyl edges.
rusty baker 05-28-2009 11:27 AM
Wood or concrete floor? The only reason I ask is, floors usually rot out at sliding doors. If it is a wood floor, you need to check for rot and repair first.
Floorwizard 05-28-2009 04:03 PM
Ericka,
yes, undercut is fine.
yes, the edge goes. but the transition is called an end cap or baby threshold. the carpet butts up to the transition, it does not go under it.
dont make the mistake of using a t-mold.
It requires more cuts, more waste and adds difficulty if your going to install diagonal.
make sure you feel OK with this.
as Bill said...cut the curls in the Vinyl.
By the way...THANK YOU for the pics.
you may not know...but it makes a WORLD of difference for us!
your awesome
