Old 03-01-2006, 10:59 PM   #1
Laminate Flooring Question
I just had laminate flooring installed over a concrete subfloor. I have the quiet step padding installed under the laminate. Is it normal to feel the seams of the laminate flooring when you are walking over the floor? When I rub my foot (barefoot or with a sock of course) over the floor I can feel the seams. Is this normal with laminate or did the installer do a bad job? Thanks
cacell is offline   Reply With Quote
Old 03-01-2006, 11:29 PM   #2
jproffer's Avatar
I would say it's not normal. But if anyone did a bad job it wasn't the installer, it was the manufacturer. The tongue locks into the groove wherever it fits...if that leaves an offset then it was made wrong to begin with.
What brand of laminate? How "tall" are the offsets? (what I'm getting at is....the thickness of a piece of paper?...the thickness of a soft book cover?....more?
jproffer is offline   Reply With Quote
Old 03-01-2006, 11:42 PM   #3
The manufacturer is Shaw. The thickness was 7MM. I think that is what you are asking.
Old 03-01-2006, 11:45 PM   #4
The offsets vary. They are large enough were you can feel them and in some area's can see them
Old 03-03-2006, 02:15 PM   #5
Floorwizard's Avatar
Seam peaking can happen if the floor was dry, and now there is more moisture in the air.
Lack of acclimation can cause it too.
how long was the floor in that area before it was installed?
Floorwizard is offline   Reply With Quote
Old 03-03-2006, 03:03 PM   #6
Not really sure. The installer bought it from his supplier and installed it while I was out of town. The installer is sending out a factory rep (shaw flooring). How long should the floor been left to acclimate?
Old 03-03-2006, 06:44 PM   #7
Contractor
3-4 days min. and I'd split the plastic at least. Ricking is better.
Teetorbilt is offline   Reply With Quote
Laminate Flooring Outdoors fogel1497 Flooring 1 05-28-2007 04:39 PM
Laminate Flooring Question MillerClemsonHD Flooring 4 02-17-2007 04:49 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 11:48 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
