Laminate Flooring Quarter Round Cuts - Flooring - DIY Chatroom Home Improvement Forum
Old 12-09-2006, 01:37 PM   #1
I have install the laminate floor and now need to put down the quarter round. Question #1: Do I nail to the wall or angle down to the floor away from the laminate so the floor can still float? Question #2: I have outside corners greater than 90 degrees and am having difficulty making those cuts. Any help would be appreciated.
no3jack is offline   Reply With Quote
Old 12-11-2006, 09:30 PM   #2
remodeling pro
I like to use long nails and drive them on enough of an angle that they miss the laminate, alowing it to still float,but also put a little downward pressure on the floor to help hold the quarter round tight to the floor.Do not nail through the floor, because if there is a problem and you call for a warranty claim, the rep will immediately jump on the fact that the floor could not float any longer, so sorry we can't help you, good bye.Most miter saws will cut a few degrees more than 45, but if that is not enough make a little wood jig to clamp to your fence . Make it a convenient angle to work with, like 10 degrees. Use it for the fence to hold your quarter round. If you determine that you need a 55 degree cut, set your saw to 45 ( 55 minus the 10 built into the jig)
troubleseeker is offline   Reply With Quote
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
moulding, laminate flooring sequence, need quarter round? KUIPORNG Flooring 6 03-10-2009 01:45 AM
Quarter round in basement? xray328 Carpentry 5 07-24-2007 07:08 AM
How much does laminate flooring expand or contract peter1 Flooring 5 03-27-2007 08:23 AM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 08:39 PM
