Laminate Flooring And Pool Table - Flooring - DIY Chatroom Home Improvement Forum
Old 06-01-2008, 07:05 PM   #1
Laminate flooring and Pool Table
I am finishing my basement and am thinking about laying laminate floor. I am adding to a room which is already finished and does not have a sub floor. Can I put laminate on top of concrete with simply a vapor barrier? Is it a good idea? Will the laminate pucker under the weight of my pool table? Is there a certain thickness that would be recommended? Any help would be greatly appreciated!
Thanks,
Mike.
OBaNioN is offline   Reply With Quote
Old 06-02-2008, 02:15 PM   #2
Use a vapor barrier. Concrete will 'wick' moisture. Whether it will pucker or not depends on how flat the floor is.
If there is a dip or a rise where one of the legs sits it may show on the floor. It would probably be a good idea to spread the weight of the table out if you can think of a way. Just an opinion..
harvster is offline   Reply With Quote
Old 06-05-2008, 10:45 PM   #3
You may want to consider adding a strong material just under the table. Tile would work fine. That way you know it will support the pool table. One tip for moving a table around is to put casters (with wheels) under the legs. Much easier than lifting an 800 pound monster!
Allison1888 is offline   Reply With Quote
