Old 02-15-2010, 04:03 PM   #1
sda
Laminate flooring over tile
I want to install a laminate floor in the basement. The basement now has 'prees & tile' installed over sealed concrete for the last 30 years. Do I have to install a vapor barrier or is the previously installed tile sufficient?
sda is offline   Reply With Quote
Old 02-16-2010, 06:53 AM   #2
Most manufacturers require an isolation membrane of some kind, usually theirs. Follow directions. To not install one may void the warranty.
Carpeting AND Laminate Flooring over Tile??? Scotsman General Discussion 1 11-23-2009 03:38 PM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 08:34 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Replacing tile with laminate - Bad idea? Regina Phalange Flooring 6 11-22-2008 07:12 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
