Laminate Flooring Over Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 08:13 PM   #1
laminate flooring over laminate flooring
Can I put laminate floating floor over the current laminate floor that I'd there? The current flooring goes under the kitchen cabinets. It is 16 years old and glued together.It is in good shape but we want a change. This is in a modular home and I thought the extra thickness helps the floor and sound. Because it is glued together I would have to cut it up in sections to get it out. Any thoughts good or bad? Thanks
bowbender6 is offline   Reply With Quote
Old 07-01-2012, 09:05 PM   #2
Rewards Points: 14,000
Are you sure it's not linolium instead of laminite flooring?
Reason I ask is I'm not sure laminites even been around that long, it's almost never glued unless it's installed over a slab, and it's never suppost to be installed under cabinets.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
JetSwet (07-01-2012), rusty baker (07-01-2012)
Old 07-01-2012, 09:23 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
It can't be laminate if it's that old, post a pic!
JetSwet is offline   Reply With Quote
Old 07-02-2012, 06:37 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
No!.................
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-02-2012, 07:05 AM   #5
It is Laminate ,Mills Pride when it first came out, I bought it a Home Depot in Grand Rapids when we first bought the house, I put it down and glued it together, It was a real pain. It is above grade no moisture issues. I could screw it down but I am leaning towards pulling it up. Thanks
Old 07-02-2012, 08:14 AM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
I would pull it up, your going to end up with to much flex.
Old 07-04-2012, 09:27 PM   #7
Thanks, looks like I'llpull it up
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 05:57 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
