Laminate Flooring Over Ceramic Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 12:23 PM   #1
Rewards Points: 77
Laminate flooring over ceramic tile?
Did a bit of searching but didn't find this exact scenario. We have a finished basement in our 50-year-old split level, and the previous owner tiled the entire thing. I'm not a huge fan of tile in general, and we'd like to make the lower living area our kids' playroom (4yo and twins due in April). Don't really want them playing on hard tile. Would like to cover with laminate flooring, which I've installed several times. Never done it over tile, though. I believe it can be done, but I'm worried about uneven tiles. The previous owner did a hack job on many projects, including the tile. Several are loose. Would it be prudent of me to tear these tiles up and re-set them prior to laying the laminate? Or will I not even notice?
Proulx06 is offline   Reply With Quote
Old 01-18-2011, 01:43 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
If the floor isn't flat, laminate at the least will be noisy, at the worst, it will fail.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-18-2011, 02:58 PM   #3
woodman58's Avatar
Have you ever thought about a floating cork floor. It has many patterns and is very tough. It would be soft on the kids, also. I would reset the loose tile and put a layer of 1/4 inch sheet cork over the tile before installing any floating floor. You can use any floating floor over the 1/4 inch cork. Unless it is very uneven this should make up for any unlevel area. You can research one product called Amcork. There are many other different cork manufacturers.
http://www.amcork.com/flooring_list.asp
P.S. You will have to contact them for the 1/4 inch roll cork.
woodman58 is offline   Reply With Quote
Old 01-18-2011, 05:52 PM   #4
Rewards Points: 77
So wait, is the cork just an underlayment for the laminate flooring, or can it be used as flooring itself?
I'll look into it either way, although my favorite thing about laminate is how inexpensive it is.
Old 01-18-2011, 09:17 PM   #5
woodman58's Avatar
Go to the link in my previous post. They sell cork flooring. The sheet cork can be used under any laminate instead of the foam.
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 08:55 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
ceramic tile transition to laminate Kman92592 General DIY Discussions 1 07-01-2010 09:55 PM
