Old 06-23-2010, 09:56 PM   #1
Laminate flooring over carpet?
I'm remodeling a rental apartment and was planning to pull up the yucky carpet and put down Pergo and some cheaper similar laminate flooring. But checking it out today I found 3 layers of carpet, all flat commercial type, and the bottom layer seems to be glued to the floor. I think it was some kind of foam backed stuff. Pulling it up will likely be a terrible job. Anyone think I can just pull off the top two layers of carpet and lay the laminate on top of the old carpet?
Dianebc is offline   Reply With Quote
Old 06-24-2010, 06:55 AM   #2
Doer of Many Things
poppameth's Avatar
I've seen it done over a single layer of extremely short pile loop commercial. This was directly glued with no pad. It worked out well and has held up for several years. If there is a foam pad under it you are probably asking for trouble. Going over carpet period generally isn't recommended.
poppameth is offline   Reply With Quote
Old 06-24-2010, 12:56 PM   #3
Handyman
If its the short nap industrial type carpet you have you should be fine.
canadaclub is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
put carpet on laminate > dainova Flooring 3 06-15-2008 08:49 PM
