Old 05-21-2009, 01:46 PM   #1
laminate flooring in mobile home
I'm new to posting, so please excuse me if I flub up. Has anyone installed laminate in a mobile home ? How level/flat does the floor really need to be? What's the best way of getting it level? (We had a "releveler" out 6 mos ago, but it only made it better--didn't cure the problem). Also, I've read that you need to install laminate across, rather than parallel to, the joists? Does it matter? I'd appreciate any info or experiences you can share. Thanks, Tralf.
Tralf is offline   Reply With Quote
Old 05-21-2009, 05:36 PM   #2
Floorwizard's Avatar
it doesn't matter which way you lay it, but in most moble homes, running it the long way down the length of the home looks best.
1/4 within a 10 foot wingspan usually but you need to check with the manufacturer of whatever you buy
Floorwizard is offline   Reply With Quote
Old 05-21-2009, 06:50 PM   #3
Thanks floorwizard
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 47 03-20-2013 10:48 AM
Laminate flooring - Question on Flooring Brand Locksley Flooring 3 09-09-2009 09:35 AM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
reflooring mobile home texas fishing port shu246 Flooring 1 06-25-2006 04:01 PM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 05:09 AM
