Laminate Flooring Install - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2006, 02:44 PM   #1
Question
I am going to be installing Laminate wood florring in a house and have a question. The flooring will cover the whole first floor (except the entry hall and bathroom). Should I cut the floor and add a threshold for the bedrooms or just one straing shot wall-to-wall, room-to-room. I know I need to leave a gap, but I have never installed Laminate flooring for the WHOLE House before!
Renovator is offline   Reply With Quote
Old 04-21-2006, 05:41 PM   #2
Contractor
How long is the run and how good is the flooring?
Teetorbilt is offline   Reply With Quote
Old 04-21-2006, 08:44 PM   #3
Check the flooring documentation it should give recommended distances between expantion joints.
MoJoe is offline   Reply With Quote
Old 04-21-2006, 11:22 PM   #4
I think you will find thresholds should be used in all doorways.
lxdollarsxl is offline   Reply With Quote
Old 04-22-2006, 10:34 PM   #5
Floorwizard's Avatar
I agree. thresholds allow rooms to move seperately.
Floorwizard is offline   Reply With Quote
Old 04-24-2006, 08:40 AM   #6
Well....The flooring is Not what I would have selected (i.e. she bought the cheapest). The Total Length run is about 40 Ft and width run is 29 ft. See attached pic (Brown represents where the flooring goes. Each square represents 1 sqft).
Old 04-24-2006, 10:42 PM   #7
that says it all.
transition every doorway.
Laminate Flooring Question cacell Flooring 7 03-30-2017 08:01 PM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Laminate Flooring Outdoors fogel1497 Flooring 1 05-28-2007 03:39 PM
How much does laminate flooring expand or contract peter1 Flooring 5 03-27-2007 07:23 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
