Originally Posted by rb_in_va
I am having problems installing a laminate floor. The instructions say to join the end of the plank, then tilt the pieces up and into the long groove. This works fine for 2 pieces, but when I do three pieces the part I just completed pops out. And I have up to 5 planks to do in this room! Help!
rb,
We usually snap the planks in one at a time (on the long sides) and then use a design specific (Matches the exact tab end contours of the plank)
'tapping-block' ...... to tap the plank into the butt end of the previously laid planks....
Do you have a taping block for the flooring that you are installing?
It's important that all joints fit snuggly....
