Laminate Flooring - Glue Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 12:09 PM   #1
Laminate Flooring - glue removal
I recently ripped out some olllllld lanolium in our kitchen and there is still some glue left from it on the concrete. It isn't all that thick. Is it fine to lay the underlayment over the top of the glue? If not are there any easy ways of removing the glue? it seems to be stuck fairly good and the scrapper i have doesn't seem to be able to pull it up.
armsteadj1 is offline   Reply With Quote
Old 12-16-2009, 12:21 PM   #2
msv
Hardwood pro
msv's Avatar
HD/Lowes have razor blade scrapers that work really well for this type of situation. if the glue is dry and it's not affecting the floor being flat, you sohuld be ok leaving it there... but try those scrapers... buy a couple of spare blades...
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
Laminate flooring over old glue?? TomC723 Flooring 2 08-19-2008 12:33 AM
