Laminate Flooring In Frame House - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 09:41 AM   #1
Question
Laminate flooring in frame house
I have a frame house (on blocks) that has the typical frame house movement problem. Other than an occasional sheetrock seam separation, I have no problems with it. I am considering replacing the carpet with laminate flooring because of the cleanliness issue but my wife tells me that laminate flooring would buckle in this type of house. I was under the impression that laminate flooring was actually a floating floor and that it wouldn't move if the house shifted. Your opinions please.
goodag2 is offline   Reply With Quote
Old 12-08-2012, 10:54 AM   #2
Rewards Points: 13,694
As long as the floor is flat it will work fine.
Old 12-08-2012, 10:57 AM   #3
and make sure to leave the required expansion gaps around the perimeter.
Old 12-09-2012, 07:00 AM   #4
Thank you, fellers. That's what I was hoping.
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Bubble in Laminate Flooring ClumsyCarpenter Flooring 3 11-23-2010 05:38 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Framing a Closet & Laminate Flooring Chuck Remodeling 5 01-02-2007 11:35 PM
