Old 12-27-2011, 11:49 PM   #1
Laminate flooring direction.. odd?
I have a dilemma with my flooring, and which way to lay it.. I know the common rule of thumb is to lay it along the longest wall... Which I was going to do.. But here is the question I have.. When I go down the stairs to my basement, get to the bottom, and look left into the room, the wall to my far left is the longest wall.. but from that wall, to the right of me, to the end of that "hallway" is the longest run in the area.. which one do I go with? Some pictures to better describe what I mean..
Going down stairs,
"Longest Wall" the dark one..
From "longest wall" to door, is longer than "longest wall"...
Thanks for the help guys!
casper129 is offline   Reply With Quote
Old 12-27-2011, 11:55 PM   #2
i would go with the long wall to the left.
Old 12-27-2011, 11:56 PM   #3
That's what I was thinking also.. I had laid it both ways for a run or two, and the wife couldn't make up her mind.. so, now I can point the finger at the interwebz if she doesn't like it Thanks!
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Which direction to install laminate flooring - Floorplan attached oONightFireOo Flooring 8 01-31-2010 04:01 PM
direction of laminate flooring reds_21 Flooring 1 11-12-2009 08:48 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
What would be the best direction for my laminate flooring? dotrn Flooring 1 06-29-2009 02:01 PM
