Old 10-09-2010, 11:20 AM   #1
laminate flooring contracting at sliding door
Hi
We put laminate flooring in our dining room and this morning noticed that it was contracting where our sliding door is. My question is what do we do about the contraction infront of the slider? We can't put 1/4 round there can we?
thanks in advance
ckgwalk is offline   Reply With Quote
Old 10-09-2010, 11:39 AM   #2
Not a pro, but they make transition molding to allow for the needed gap for expansion.
http://www.homedepot.com/Flooring-La...atalogId=10053
tribe_fan is offline   Reply With Quote
The Following User Says Thank You to tribe_fan For This Useful Post:
ckgwalk (10-10-2010)
Old 10-09-2010, 07:56 PM   #3
Tileguy
JazMan's Avatar
Yup, that's similar to the right piece that goes in such areas. There are several variations, but essentially all do the same thing. That one is for carpet to laminate or wood. You'll have to remove or cut back the laminate of course.
This is actually the molding you need. Notice the back side is not rounded like the one for carpeting. http://www.google.com/imgres?imgurl=...1t:429,r:2,s:0 is also used where flooring meets a hearth or brick wall, and many other such situations.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
Old 10-10-2010, 12:28 AM   #4
Thanks so much for your replies.
There is only a 1/4 inch space between the sliding door and the laminate?
How do I cut the laminate if its already installed? Is it posible to cut/thin out the trasition strip instead?
Old 10-10-2010, 09:26 PM   #5
Tileguy
JazMan's Avatar
No, not really. You have to leave a gap for expansion, that's why you have the problem now. A router would cut it the length and notch the sides too. Do you have just a few pieces which run the length of the door, or many end pieces to cut? Well, either way a router will make the cut without removing anything. Just set the depth of cut, set up a straight edge as a guide, fairly simple.
Jaz
Old 10-11-2010, 12:05 PM   #6
Tileguy
Bud Cline's Avatar
How about a picture?
2x4 sliding door over 2x6 walls Hexar Building & Construction 4 04-19-2010 05:03 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 08:34 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
