Laminate Flooring On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 04-19-2008, 09:55 PM   #1
laminate flooring on concrete
Own an earth home and am considering laminate. Anyone have experience with it over concrete. Is it really cold in winter? we have no moisture probs. thanks.
woodeye is offline   Reply With Quote
Old 04-20-2008, 11:41 AM   #2
I just installed some 12mil laminates on concrete subfloor. It's definately not as warm as carpet, but you can use a very thick cork underlayment for some good insulation. We went with a 6mil cork. Also, you'll lay a vapor barrier (thick black plastic taped at the seams) for the moisture, so it's not an issue anyway. Just make sure that the brand you are buying is approved for below ground installation.
blschmitz is offline   Reply With Quote
Old 04-21-2008, 07:07 AM   #3
so-elitecrete
Rewards Points: 150
ambient earth temp's, what - 65 - 68f or so ? ? ? - that's going to be the floor temp, too,,, area carpets & acid-stain'd be my choice.
so-elitecrete is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Laminate flooring using Platon underlament on concrete swany Flooring 9 09-16-2010 07:35 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
Laminate Flooring over Concrete kimmyb Flooring 1 01-28-2008 11:08 PM
