Laminate Flooring And A Cedar Closet - Flooring - DIY Chatroom Home Improvement Forum
Old 03-13-2008, 01:33 PM   #1
Question
Laminate Flooring and a Cedar Closet
We're replacing the floor in our living room, dining room, kitchen, and hallway with laminate flooring (Harmonics brand at Costco, made by QuickStep, Cabin Maple). The kitchen was vinyl, installed when we moved in 12 years ago; the living room is currently carpet, also installed when we moved in; and the hallway is a pink tile from the 1970's.
The question is what to do with the coat closet, which is 2' by 3', and currently with a cedar floor. One thought is to keep the cedar, as every one likes a cedar closet, even if it's only the floor. Another thought is to replace it, to have a uniform surface; and because it's probably over 30 year old.
If we do decide to keep the cedar floor, should it be sanded?
StevenS is offline   Reply With Quote
Old 03-13-2008, 04:52 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the cedar is "aromatic cedar" and of course it is, the way to renew its effectiveness is to sand it from time to time.
Whether or not you cover it is up to you, seems a shame to do so.
Old 03-13-2008, 10:45 PM   #3
Floorwizard's Avatar
then again it's just a closet.
if it's easy for you to refinish then do so.
if not, then cover it up.
good luck!
Floorwizard is offline   Reply With Quote
Old 03-14-2008, 09:02 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Then again it's a "cedar closet".
If you feel it is even slightly
beneficial to you then keep it.
Old 03-15-2008, 12:42 AM   #5
My wife purchased some of those small cedar blocks and they smelled great.
I forgot about that...
I can see now the value of an entire floor even that small.
Old 03-17-2008, 11:28 AM   #6
Hey Steven, I'm also in the process of installing the costco laminate flooring. Have you started yet? I am leaving the cedar in all the closets, I even had to buy some more to replace some of the closet flooring.
amdspitfire is offline   Reply With Quote
Laminate Flooring Question cacell Flooring 7 03-30-2017 08:01 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 09:01 AM
Framing a Closet & Laminate Flooring Chuck Remodeling 5 01-02-2007 11:35 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
