Laminate Flooring And Brick Walls - Flooring - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 11:02 PM   #1
Rewards Points: 113
Laminate flooring and brick walls
Where I will lay the laminate flooring will be brick walls. I will leave the 1/8' expansion gap and plan to put qrt round down. How do I attach the qrt round to the bricks---with construction adhesive? The brick walls are of old used bricks. Beautiful walls but no absolute straight lines. Since the bricks are not in perfect alignment with each other and there are the standard mortar joints, I anticipate plenty of gaps between the qrt round and the bricks. Is there a way the make this look like a professional install with no gaps? I've used caulking between wood and bricks before and it just doesn't look good. I haven't found a good way to smooth out caulking on bricks and mortar.
Captflx is offline   Reply With Quote
Old 11-24-2011, 01:14 AM   #2
How many linear feet of brick wall are we talking about? And how patient are you with tedious work?
Evstarr is offline   Reply With Quote
Old 11-24-2011, 06:48 PM   #3
Rewards Points: 113
laminate flooring and brick walls
About 50 LF of bricks and I can do tedious work and my patience depends on how successful my efforts are.
Old 11-24-2011, 07:26 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Undercut the brick deep enough so as to be able to tuck the laminate and still leave an expansion-gap deep inside the cut.
The Following User Says Thank You to Bud Cline For This Useful Post:
rusty baker (11-24-2011)
Old 11-25-2011, 11:15 PM   #5
Rewards Points: 113
lamiante flooring with brick walls
Now I understand why you asked! I see alot of dust in my future.
Thanks.
Old 11-26-2011, 10:56 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Get a helper to use a Shop Vac and catch most of the dust as it comes off the grinder.
How should laminate flooring be secured next to brick? thecgmguy Flooring 1 09-07-2010 12:16 AM
Laminate Flooring bjjunkmail Flooring 2 06-03-2010 08:43 PM
need flooring recommendations for an 1890s 4-sqaure brick house Williamstown Flooring 0 02-01-2010 08:44 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 08:42 PM
