Laminate Flooring In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 11:06 AM   #1
Laminate flooring in basement
I'm in the process of finishing the basement in one of my houses. I have a 10x10 room which will be used as an office. The basement has never had moisture problems and the concrete floor in this room is very flat and smooth. I am wondering if is sufficient to simply lay foam underlay with vapor barrier on the concrete and then install flooring? or do I need something more? I need to do this as cost effectively as possible, so what are your thoughts?
gdoucette is offline   Reply With Quote
Old 06-10-2010, 01:46 PM   #2
Handyman
Rewards Points: 512
No problem I can think of. Do it all the time.
canadaclub is offline   Reply With Quote
Old 06-10-2010, 09:01 PM   #3
I agree, as long as you have the vapor barrier, you should be fine.
Tia
flooringgirl is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Questions About Laminate Flooring OldManJim62 Flooring 8 09-23-2010 09:47 AM
Laying down laminate flooring on a concrete floor Joey_1984 Flooring 10 10-04-2009 08:42 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Basement Flooring ... njchan Flooring 3 03-19-2008 06:02 PM
